I know on some Tesla packs the cells are all glued so you can't "rebuild" the pack easily but on Volt, Bolt, as well as the new Ultium stuff, I think they could do module swaps at the dealer. I read a few people in Volt FB groups who had modules replaced on their batteries under warranty vs the whole battery had quiet poor cell balance after that when read via OBD2/apps.
Yep, started at least a few house fires from Ford vehicles parked in a garage that had spontaneous combustion causing significant damage to the house interior.There was the Ford cruise control switch recall a while back that was both big and inflammable.
It’s a recall. Just being electric isn’t a reason alone to park outside. Don’t be ridiculous. The gasoline car doesn’t just magically not have electrical components. No vehicle should be parked inside with your reasoning.Yes yes there have been ICE vehicle recalls for fires starting and park outside. 96 F250 is one of them.
And plenty of EV's too.
The most important FACT is, these fires are all related to something ELECTRICAL going bad and causing the fires.
Never do you need to park a gasoline powered car outside because the gasoline is going to spontaneously combust.
The problem is ALWAYS ELECTRIC.
If you park a car or lawn mower powered by ICE, recently operated, in a garage, that has something flammable on hot exhaust parts then yes the potential is there to start fires.
Electrical is always an issue, even your house wiring.
I don’t see a point in have an attached garage to begin with and it seems to either be a point of manufacturing simplicity or in some cases needed space saving. I’d rather have the garage detached.This is why I bought a house with a detached garage.
Really? Nothing special about EV's? What about spontaneously thermal runaway lithium ion batterys? And many times triggered by charging? Li batterys are something special, just do a search for fires caused by them. Even lawn and hand held power tools.Having spent a decade as a volunteer fireman when we were still part of a township, I can tell you that cars do catch fire and burn, sometimes when they're just parked outside.
If I had an attached garage, I'd be hesitant to park our cars in it. Any fire would quickly spread into the living areas and the time that you'd have to escape is very brief.
Nothing special about EVs since I ran on fires involving many ICE cars, some of which were just parked, with no EVs at that time.
Jeez, like 25 years ago now. Was on the 92-97 trucks.There was the Ford cruise control switch recall a while back that was both big and inflammable.
What I intended to convey is that ICE vehicles catch fire as well, even when parked. A car fire is pretty catastrophic for any vehicle and almost always results in a total loss. The only question is whether they are more or less common with EVs than is the case with conventional vehicles.Really? Nothing special about EV's? What about spontaneously thermal runaway lithium ion batterys? And many times triggered by charging? Li batterys are something special, just do a search for fires caused by them. Even lawn and hand held power tools.
If you read what I said, that is what I also have mentioned about ICE car fires, but it is most always caused by an electrical issue.What I intended to convey is that ICE vehicles catch fire as well, even when parked. A car fire is pretty catastrophic for any vehicle and almost always results in a total loss. The only question is whether they are more or less common with EVs than is the case with conventional vehicles.
I will say that it's really easy to extinguish an ICE vehicle fire with water spray. Aqueous foam will not put out any fire that water won't. It's intended to blanket any flammable liquid spills and prevent re-ignition.
This is what you wrote in the post that I replied to:If you read what I said, that is what I also have mentioned about ICE car fires, but it is most always caused by an electrical issue.
New car fires tend to be electrical failures for sure followed by poor routing of fuel lines in engine bays. I’ve now owned two vehicles that were known for rupturing fuel lines on engine covers because they did not use braided lines near the sharp area where it went through the cover.This is what you wrote in the post that I replied to:
Nothing in your post about ICE car fires, which are often caused by fuel leaks, not almost always by electrical issues.
I don't see that here, but I recall being younger before I bought my first house seeing that a lot and I was determined as a car guy to actually get my vehicles in out of the elements once I had a garage. I saw it as a garage was a place to park cars and if I was going to plunk my hard earned money down on a property with a garage I was going to use it for that purpose. I feel better about having the outlet for the car inside away from the elements anyway now that we own an EV.My observations in our area are nobody parks in their garage, its full of junk that you couldn't get $100 for at a yard sale.
so where are all these garage users?
That is because you didn't scroll up to my post that is in the #25 position above.This is what you wrote in the post that I replied to:
What about hot Exhaustgasses?Yes yes there have been ICE vehicle recalls for fires starting and park outside. 96 F250 is one of them.
In that post you contradict yourself.That is because you didn't scroll up to my post that is in the #25 position above.
