Hi all,
I'm in the process of trying to find the draw(came accrosee the forums in searching).
I've have measured the draw in series from the - terminal.. 11.6A.
I've pulled all the fuses / relays in the engine bay box 1 x 1 to check if the draw drops.. no change.
I'm next going to pull the fuses in the cabin box to try the sazme thing..
Problem here is the fuses are those tinly type B ones..
Can I also measure the voltage on the fuses determine the one that may be causing the draw? (I'm not fully certain of this).
They're in a very difficult spot to remove without the correct tool.
