PAO or Ester ?
LA CA
Which syn basestock is better, a PAO or Ester?
I recently found out by some team factory mechanics, that the Superbikes & MotoGP teams use mostly ester based oils, regardless of brands.
What basestock is Amsoil & Mobil 1 motorcycle oil? PAO?
Is Redline motorcycle oil an ester?
I know AGIP & Motul are, are they better?
TIA Alex
Amsoil is PAO
Redline is Ester
You will find that what is best depends on application and the total package. (Base oil and additive package)
Many times a Group III oil with a good additive pack or a Group III mixed with some PAO or Ester is the best overall choice.
Neither are optimum by themselves. PAO has little to no polarity/solvency/seal swell, and 100% esters have too much. Most PAO based oils have some esters or ANs to help improve polarity/seal swell and most ester based oils have some PAO to keep seal swell in check. It can get real complicated with all of the different esters out there, but that's the general idea. Esters do have much better inherent lubricity, based on everything I've read on the subject.
PAO
Redline motor oils and gear oils all use polyol ester base stocks.
No such thing as "better." They are for different purposes.
PAOs have better cold flow, resist chemical contamination very well, and cause seals to shrink and harden. Esters stick to metal and form strong films, resist high temperatures very well, and cause seals to swell and soften. Neither one would make a very good engine oil on its own, except maybe for very specialized purposes.
There are also group III+ base stocks, which are also considered synthetic. Those are like PAOs in some ways, better in others, and only worse in terms of cold flow.
Most good oils will be some kind of mix of the above. It's entirely possible that the most important ingredient (and thus the one the oil advertises) is only present in relatively small amounts; some of RLI's BioSyn oils and Nissan's Ester Oil are examples of this. This is one reason why it's impossible to say one oil is better than another one just because of what the company claims it's made of.
As far as comparing brands, all the ones you named are good. If you pick out specific products, maybe we can narrow down the comparison a little.
What is a double ester formula?
That's Motul code for "we use two different kinds of esters, but we won't tell you what kinds or how much of each."
I take it you're looking at 300V?
That's a Motul marketing term, and I have no idea what it means.
Thats a good way to put it. 300V is a great product. I like redline myself. It all comes down to what your driving, habits are. For most daily driven cars groupIII+ oil are fine and PAO are to. Group V oils maybe considered overkill for most, but I like them. If your car is turboed or DI, motul and redline are pretty tough to beat.
The oil will be for my Ducati Hypermotard, a 1100cc air-cooled L-twin, I use it for canyon riding and track-days,the motor has been highly modified, and HP to the rear wheel is up from 80HP to 106HP, about 30%. I live in SoCal and the tracks in the desert can get real HOT!
So my choices would be:
Amsoil 20W-50 (MCV) "PAO"
Redline 20W-50 motorcycle oil "ESTER"
Mobil 1 20W-50 V-Twin motorcycle oil "PAO"
So what do you guys think?
TIA Alex
Originally Posted By: BobsArmory
Originally Posted By: Ben99GT
Here's some reading on esters if you're interested:
Esters information
Good information there!
From my reading it means that i can mix polyol esters (pag oil)or refrigerant oil in my synthetic oil for better lubrication Or I can just use airplane engine lubricants like avblend. See ,I learn something new every day.
Originally Posted By: ZZman
Amsoil is PAO
Redline is Ester
Not 100% true. (but often repeated on BITOG) And you can see this misinformation has lead the OP down the wrong path.
Amsoil has PAO's, Redline has PAO's. Amsoil has esters and Redline has esters. Depending on which oil we are talking about Redline probably does use more esters in their motor oils, but some/most are 30-40%+ PAO. Amsoil is probably higher at 50%+ PAO.
Amsoil is PAO
Redline is Ester
At what percectage of an ingredient, do thet have to have to advertise that their product is a PAO or Ester? over 50%? like 51%? if so true, why not advertise it? if Esters are better? Thanks Alex
Originally Posted By: DieselTech
Redline in the Duc!!
Redline uses a lot of moly -- could be a problem if that Ducati has a wet clutch. I know some of the newer ones no longer have dry clutches.
I vote for Maxima or Motul if you want oil with ester in it. Amsoil or Mobil 1 if you want PAO.
^^ This.
Read it, know it, love it.
They can advertise whatever they want, really. It's whatever they think is the most important (or most attention-grabbing) part of the oil.
Besides, what the oil is made of doesn't tell you the whole story. Any combination of base stocks could lead to a great oil or a terrible oil.
This is why, when you're trying to decide what oil to use, it's best to focus on the performance of the oil rather than what it's made of.
Amsoil is PAO
Redline is Ester
It's not misinformation, IMHO. Redline uses Polyol esters as their base stock, Amsoil uses PAO as theirs, hence RL being considered an ester oil and Amsoil a PAO. So calling RL an ester oil and Amsoil a PAO might be overly simplified, but it's essentially accurate and not leading anyone down the "wrong path".
Sure, Amsoil contains other ingredients to compliment the PAO and RedLine uses PAO as an additive carrier (this comes straight from RL), but I'd be willing to wager their respective percentages of esters aren't even close. FWIW, I e-mailed Dave at Red Line about the respective differences between the base stocks in RL's street and race oils. Here's what he said:
Originally Posted By: Dave @ Red Line
Ben,
Thank you for contacting Red Line Oil, the Race Oils and Motor Oils contain the same base stocks, the differences is the additive packages being optimized for each intended use.
Regards, Dave
Red Line Oil
Which brings me to my next question; where are you getting these percentages from? RL doesn't share this information, and I'm pretty sure Amsoil doesn't either.
