Painting windshield wiper arms
Myrtle Beach, SC
I replaced the windshield cowl yesterday and I had my wiper arms off, and I would like to paint my wiper arms, or have a friend of mine do it, have COPD and asthma.. I don't know what the best paint would be and if I should clear coat or not? I've seen on Google, everything from engine paint because of the high heat of the Sun and windshield, to trim and bumper paint. Thank you for your help..
What have you used on yours?
How long has this held up?
Typically, it will look good for 3 or 4 years. The key is to prepare the wiper/trim by removing all rust and roughing up the surface if it has old paint. Sandpaper works, but it is much easier to use a Dremel tool with a fine wire brush wheel on irregular surfaces like wiper arms. A quick wipedown with isopropyl alcohol or Dupont Prep-Sol will remove any oils before spraying.
