Originally Posted By: parimento1
I looked at the igniter wiring and underneath it, if you twisted the wires, was an exposed wire whose insulation had rubbed off. So I wrapped it with electrical tape, but no difference, after a few on/off cycles, the light came on again and did not go off until I warmed up the car, turned it off, then turned it back on again. It is very hard to get the light to come on when it is at operating temp, but when it is cold it is almost a sure thing. As far as the other wiring, I checked all the exposed wiring. The ones that are sheathed I do not want to touch, as it is a major PITA to unwrap them and might create more headaches. But I checked the wires at the both the computer connector and at the igniter, as well as at the coils, and all except for that one wire at the igniter looked good as new.
This does sound like it was contributing to your problem. It may not be the only thing, but if it was tripping a p1300 igniter code, and some of the insulation on the wire rubbed off, it could have been shorting to ground.
I'd try a couple things. First I'd get a bottle of the Genuine Toyota EFI Cleaner. This stuff is the most potent fuel injector cleaner I've ever seen. Even better than Techron. We once had a parts van at work that was not running well due to clogged injectors. We ran this stuff and in 10 minutes it was running like new. It comes in a small black bottle (New package), or a small silver can (old package)
It's only a couple of bucks, and is available at you local Toyota dealer. Next clear the code, and drive it. You may even want to wipe everything, by removing both battery terminals, and touching them together for 10-15 seconds. This will discharge the capacitors in the computer and wipe it's memory. This way you can start from scratch. Let us know if it comes back.
Justin
