2013 Acura RDX P0303 code fixed now P0174
Cow Hampshire
I had a misfire fixed with new coil/plug rear bank of 2013 Acura RDX(185k) drove 20 miles and then new code P0174 which seems to be rear bank according to ChatGPT . Are these related typically? I will will drive 500 miles this week commuting and get looked at by same mechanic.
P0174 is bank 2 system too lean, and on a transverse V6, bank 2 is the front. Often caused by a vacuum leak or an oxygen sensor.
What kind of coils did the shop use?
  • Like
Reactions: wlk
The diagnosis of misfire was based on moving the coil and code followed to next cylinder . The entire repair was $250 for diagnosis and coil by a component mechanic.
I had the codes backwards(before coffee today) :unsure: I thought you were getting a misfire after.
I'd suspect they disturbed something with the repair that caused a vacuum leak.
It might be something crumbled/cracked having 13 years old engine hoses besides the more obvious didnt reassemble correctly.
  • Like
Reactions: wlk
Needs proper diag. Smoke the intake and make sure there are no leaks. Has it been confirmed that the lean condition is only affecting one bank, or is bank 1 just on the verge of popping a P0171?
