I used this tool for the 2gr I did. It might work for you as well:
www.monkeywrenchracing.com
MWR Toyotool Valve Spring Tool - 2ZZ 1ZZ 2GR 1GR 2ZR 1ZR
Finally, an easy and reliable way to service the valve springs of your 2ZZ-GE, 1ZZ-FE, 2GR-FE or 2GR-FSE/FKS (as well as many other models) without removing the head from the block or even removing the engine from the car. This patented tool, manufactured by Toyotool and specially modified by MWR fo
