P0130 '11 Ford Fusion 2.5
Rochester, MI, US, World
Yesterday our Fusion threw a P0130, upstream o2 sensor code. I cleared the code, but it came back today. I know many times a CEL for an o2 sensor doesn't always mean a bad o2 sensor. But looking at some of the Fusion forums, this does seem to be a culprit from time to time, and a new o2 sensor does fix the issue. Sometimes it looks like this code could be associated with a vacuum leak, gas tank leak, etc. This car has already eaten 3 canister purge valves, before Ford updated the purge calibration last year during a TSB. When those have failed before, a different code has appeared, so I don't think that's it. As far as a vacuum leak, I haven't done any work to the car recently and I gave everything under the hood a once-over the other day. Driveability seems the same from what I can tell. Any suggestions before I replace the o2 sensor?
o2 sensors don't last forever. and they are usually easy to replace
I don't mess around with upstream senors. That can kill your cats. I replace mine around the 80-100k mark even if they have never thrown a code.
I would not drive it much until replaced.
