2014 Cruze CTD. First UOA, purchased bone stock about 1.5 years ago w/ 50K miles. The CTD has the German Made Opel Multijet 2.0 CR Turbo Diesel AKA 2.0 CDTI. This car did not sell well in the USA, and they aren't that common. It needed a new timing belt because the water pump was leaking and some other work, but it was cheap at $8K from a friend at work. It now has 68K miles.
OZ Crzrace tuned = 185 whp and 300 lb/ft. Top Speed limiter removed and speedo/SC/TC calibrated for 225/50R18 tires ( +2% Diameter). Engine is stock otherwise. This car handled like a Buick and had an irritating suspension squeak, so I replaced the whole suspension with the following components:
With the stock 17" wheels and LRR 215/55R17 tires, this car could easily get 58-60+ MPGs at 65 Mph and 38-40 MPGs at 90 Mph. However, with the suspension mods and big rear sway bar the car was squirrely, many times the Stability control corrected the car because I took a turn to fast and the rear stepped out.
The 18" wheels and taller, wider and stickier S3+ tires dropped the MPGs by about 10%, but it's much more stable now. The stability control has never corrected the car since.
Oil is 75% RLI Biosyn HD 10w30 and 25% 15w40. Manganese is from fuel additive TDR-FL which likely contains MMT. I ran it almost 2x the normal factory interval of 7500 miles. The oil filter on this engine is small, and I pushed it as far as I felt comfortable.
- Bilstein B12 Pro Kit
- Whiteline Front Control Arm Bushings
- Whiteline Rear Sway Bar
- Every suspension mount, bushing or link was replaced with upgraded parts by Mevotech Supreme, KYB, or Sachs.
- American Racing AR928 Wheels w/ Michelin Pilot Sport S3+ tires in 225/50R18
- Camber bolts up front and rear shims allow -1.5 deg camber on all 4 corners
