A filter with better filter media will filter better than a filter with "normal" media when it is filtering. An oversized filter will allow less oil to bypass the media, therefore the question you are really asking is, "Is the wear greater or less on a smaller filter with better media"
The media doesn't change the oil pressure to the engine, so the real question is how dirty is the oil that ends up going through the bypass valve. My opinion: probably not that bad, since the oil filters through the media most of the time.
The only quantitative study I've seen on particulate quantity vs. filter media was on a JeepsUnlimited forum. It concluded that for one test (not exactly statistically significant) a Fram filter did a better job than Pure-One, but not as good as Napa Gold and the best of the bunch was Mobil 1. Since Pure-One and Mobil 1 are considered pretty restrictive filters, one cannot reach a conclusion.
Personally, I'd go with the better filter media.
