I ran a compression test recently and forgot to pull the power to the distributor. Consequently I damaged the ignition coil since the charge probably built up and internally shorted it without any ground to dissipate to. Coil damage showed up on the multimeter for secondary winding resistance far lower than spec (8Kohm vs. 13-20).
So my question is would the ignitor have been damaged too since it would've been the only path for the current to flow? The primary winding resistance is within spec. Ignitor is running the distributor fine right now, but I don't want to be stranded because of it in the future, nor do I want to spend $60+ for a new one if unneeded. This seems like a straightforward problem, I'd be grateful for anyone with an electrical background to give some guidance. Thanks.
