Over filled half quart
Originally Posted By: ZZman
No issue
x2..i always run mine 1/4 to 1/2 over,remember when that engine is running there's allot of oil being removed from the pan pumped up to the heads and other places.
I most of the oil in a running engine is in the head, you have severe problems.
But that 1/2 qt. over is mostly a mental issue that can bother you.
Try thinking of that 1/2 qt. over the whole area of the oil pan - it is only 1/16" -1/8" more.
i said allot not most.
Originally Posted By: LT4 Vette
+ half quart is better than - half quart of oil.
I agree! I always like to slightly overfill my engines and I would never run them a half quart low. In fact I top up the oil to keep mine ABOVE the full line at all times!
Originally Posted By: Cutehumor
no problem. this question comes up every few days like clockwork
I noticed this also, and I usually keep mine just over full, maybe a 1/4qt. over.
He was thinking of Loobed's post, but quoted yours.
right...
I just realized that we're both on top of it...
You "assumed" that he was responding to your post, rather than Loobed's. Meanwhile, I "assumed" that he had quoted, or replied, to your post. Turns out neither was, in fact, correct.
That'll teach me to try and be coherent after getting three hours sleep...
right...
No problem
Glad this thread is here, because, even though I've been doing oil changes for over 10 years, I accidentally overfilled my wife's 07 Chevy Equinox with Pennzoil Platinum 5w30 by about 6 ounces or so. Some would have you believe going even an ounce over is horrible. Thanks to BITOG, I now know better. I feel better knowing I didn't damage an engine. By the way, this is the first time I can recall actually doing this!
I've put in 5 quarts in the recommended 4.5 quart sump of the 3 ever since the first oil change. No problems.
