Outside AC unit valve leak
LONESTAR state
Hello everyone, I notice last a
Week or so my house temp keep climbing and it go down a bit overside, outside Texas lately is around 95.
Last couple night I been sleep with a fan. I change the filter ( inside the house ).
So today I call a HVAC tech and he found a leak on my Ac unit outside is a valve. He said it leaking oil bad.ly.
He said my unit is 13 years old I should start to get a new unit.
He said he can't warranty after replace the valve the leak stops. But to replace the valve and 9lb of Freon cost me $1,100.
He pull the outside unit fuse off but my Ac inside still running.
I don't have moneys for a new unit now, I should have renewed the homeowner warranty.
And when I up in the attic I found water drip between those 2 screw.
Man being home owner… it's what it's.
Doesn't matter that its in cool mode that will keep your inside fan running if that will help.
Is the valve leaking because of a bad joint or is it the core leaking. If its just the core that can be changed without any refrigerant loss.
Nine pounds seems like a lot of refrigerant.
Get a second opinion. 13 years old is not that old to replace it and I feel his estimate is on the high side.
I'm in the same predicament w/my 24 yr. old Rheem 2 1/2 ton outside unit. (Leaky TXV valve so was told by HVAC Technician.) I believe it's time to replace both inside/outside units. Ouch!) In your case 13 yr. old unit seems to young, so would elect to fix. But what do I know....
OK, first things first. The refrigerant leak is a specific issue that can be addressed. Address it. If it is the Schrader valve, those can actually be replaced 'in place' without liberating all the refrigerant. There is a tool that does this. And/or one can purchase a quality metal cap with "O-Ring" and screw the cap on, sealing the bad valve.
One can also purchase a 30 pound jug of refrigerant on Facebook marketplace, along with a set of gauges for a fraction of what the AC companies will charge you. Then ask a technician to do the task using your tools and supplies. Saves a FORTUNE.
Also the drip may be normal, as cold parts condense water and, well, drips happen. Or it may be that the "Evaporator" (The A coil) is not draining well and the drain pan needs cleaning. If you have access, this is generally not hard to do. One can even take a Shop Vac and suck out the drain pipe to clear it. This often works wonders!! Simple, fast, effective.
But after cleaning, there are tablets that keep the bacterial growth to a minimum. Homeless depot sells them. Put 2 or 3 in the drain pan before closing it up.
NOTE: AC repair companies are notorious for pushing people into replacing their entire AC units. Often at insane prices.
You can find the valve core tool for $25-$50. And DIY.
Same for a cap that seals a leaky valve, $10.
All forms of Freon are expensive today. But a 30 pounder can be had for far less than your $1100 repair bill. And I promise you likely have a friend or neighbor who can use your supplies to service your unit if you are not capable.
And no joke, Homeless Depot sells this Gauge set for $39.
Yeah, tech could have changed out the shrader valve without loss of any charge
