I have a 2001 Dodge Dakota, 134,400 miles on it now, 2 wheel drive, 3.9 liter V6 and a 5-speed manual. It has a problem with a clunk or pop type noise coming from the front end, usually when I am backing up and turning left or right, as in backing out of a parking space. I will occasionally hear the noise when moving forward and I make a hard stop. The noise will also occur sometimes if I just turn the wheels lock to lock while sitting still.
I already replaced the stabilizer bar bushings, the stabilizer bar end links and their bushings, uppper and lower ball joints, and inner tie rod ends. I used Duralast and TRW parts, except for the stabilizer bar bushings. Those are Moog. None of these new parts helped the noise but they all needed replacing anyway.
I had the outer tie rod ends done 60,000 miles ago when I took it in for an alignment, they used Moog parts. When I did the other work on the front end recently, I noticed the outer tie rod ends can be moved by hand. They are not loose and I don't feel any serious play in them but I can grab the stud end and turn it, move it 360 degrees in its socket easily by hand. Is that normal for a TRE? Can that amount of looseness cause this noise I hear? Is 60K a normal life span for a Moog outer TRE? Is a TRE supposed to be stiff and unable to move at all by hand?
The truck drives and steers fine. No looseness or wandering. There is a very minor and slight vibration I can feel in the steering wheel but I attributed that to bad Florida roads and the age of the truck. Shocks are Monroe Reflex front and rear and have about 30K on them. The steeering rack looks OK to me. There was no movement or play in it when I had a helper move the steering wheel while I looked at it from underneath the truck. There are no abnormal noises in the rack when steering while driving either.
I had posted here about the clunk/ pop noise a couple of months ago. I was unable to fix it then and decided to wait and see if it got worse. Now it is getting worse and I still don't know what is causing this noise. The tire shop couldn't figure it out either, but they didn't spend a great deal of time looking at it.
I appreciate any help you can offer.
