Outdoor Ethernet Switch
Near the beach in Delaware
Looking for recommendations/experience with outdoor network switches that are waterproof.
Must handle POE++ so 90W, have 4 output POE ports. Or different models with 2 or 3 or 4 ports.
I would like them to be Unifi managed switches and I have a few Unifi Flex switches but they just don't handle the power.
You can try the ubiquiti flex as a layer 2, but you will need to purchase the power brick separately for poe++.
Mikrotik has a few outdoor poe+ switches but I do not believe they provide poe++ if all the ports are taken. They come installed with their SwitchOS which is layer 2.5 and the more expensive products can do layer 3 and routing efficiently when you switch to their RouterOS.
can we get more details. POE++ out? ,In , both? poe++ can be 60 or 90 watts.
60 ?90w total? per port ?!
powered by poe?
and in general more details = better responses..
so maybe a few sentences of background?
powered by poe?
Well the entire network is Unifi. That won't change.
This section is 4 telephone poles about 125' apart I think. One run of CAT6 cable running to the first pole. First pole will be 2 cameras and 1 access point. The next 3 poles will only have access points. The access points take 10 watts, maybe a little more. The cameras take 4 watts maybe a little more.
Only power will come from the initial run of CAT6 going to the first pole. I can put in a 90W POE injector if needed. I think I have a 45 or 60 watt now.
I know I will need a switch on poles 2 or 3 or both. Switch takes maybe 5 watts.
Prefer not to run more than one CAT6 cable between any 2 poles but I could.
with that length of run even a 90w would have 70w available after a few hundred feet.
I'd also be worried about ESD with that long an antenna outdoors.
600ft of cat6 with 4 switches, 2 cameras and 4 waps.. That is abit much it needs a redesign IMO.
is there any way to get a poe injector powered somewhere on the run?
Cat 6 is usually 23gauge.
  • Like
Reactions: Pew
This is 23 gauge pure copper. The problem has always been there is no power always along this run.
I think I can do it with only 2 switches. There are various Unifi WIFI 7 access points. Some require more power than others. I may have to go with WIFI 7 access points that are a step or two back from the best outdoor ones.
right but at 300ft cat 6 is losing 20% of the wattage to heat along the wire.(or at least that is what my research says)
Are there no lights on these poles or anything?
I am looking at this switch. Maybe stay away from MokerLink. Not so good reviews.
Run 48 volts on two-conductor low voltage wire between the poles. 14 gauge should be sufficient but that needs to be backed with an exact calculation. Since the cat 6 is now only carrying data, you could consider using fiber.
