Hello,
I just purchased a new to me 2011 Outback 3.6r. I plan on doing an oil change soon and I'm confused on what oil filter to get. I know the 2.5 engines need a filter with a 23psi bypass and that besides the stock suby filter only wix makes one that meets those specs.
When I look on the Wix website it lists a different filter for the 3.6 engine with a bypass valve psi of 8-11, around the same psi when I looked on Frams website.
Im wondering if anyone knows if the 3.6 engine specs the same high psi bypass valve as the 2.5's do, or if they require a more normal bypass psi.
