Finally got around to converting the JD EZ change on E120. Even though I 'thought' I planned for it, still messy. I was glad to see I could use the longer Napa Gold 1348 (3614/10241) I had stashed, rather than OPE filter. Even with side cover plate, plenty of room. On the minus side square drain plug was a problem. In a difficult spot, luckily a yt vid said to use 1/2" to 3/8" socket adapter which I had with an extension. If interested, link is to EZ Change filter c&p I did. https://bobistheoilguy.com/forums/threads/john-deere-easy-change-cut-open.345433/
Oil Filter Adapter.
Oil Filter Adapter.
