So GM doesn't get the licensing $ for the use of the Dexcool name?Why?
*cough*2-EHA*cough*Why?
I used platinum in Toyota and it works perfect. When my avalanche needs a coolant replacement, I will fill w platinum
Not really unless you have access to a lab and the equipment to do a GCS test. There is no generally accepted color but “distinctive” per ASTM standards.Is there a way to identify what type coolant is in there?
I have a cottage in northern Mi that's heated by a boiler & finned tube baseboards. It's filled with what looks like automotive antifreeze and I'd call it "green". Propylene glycol is usually what's recommended but I've looked at several data sheets and the color can range from clear to green to red--depending on the mfr.
There's no label on the boiler.
I'm thinking there might be such a lab you could send a sample to for analysis. We take this for granted with oil analysis.... access to a lab ...
There’s coolant analysis labs for trucks/buses.I'm thinking there might be such a lab you could send a sample to for analysis. We take this for granted with oil analysis.
Clean drinkable water,,,,interestingLet’s check the owners manual of a 2022 Chev Silverado to see what GM recommends for its latest formulation.
View attachment 125403 View attachment 125404
I think this comes up every couple of years.
I have a 1997 K1500 (Vortec 350), 2000 Trans Am WS6 (LS1), 2005 Buick Lacrosse (3800), 2014 Caprice (6.0), 2015 Malibu (2.0 T) and a 2017 Chevy 1 ton (6.0)
I did the intake gaskets on the Truck and Buick. Everything else is dry intake. I run Dex-Cool or licensed Dex-Cool in everything with no issues. By now everything is an updated formula, and the LS based and anything not 5.7, 454, 3.1, 3.4, 3800 or 4.3 does not have the problem. Once you get the updated metal gaskets in the engines I mentioned you will be fine.
Prestone put a line saying distilled water is best for Cor-Guard.Clean drinkable water,,,,interesting
Why?For any car that came with Dexcool, use Peak 10x
I'm sure one of the automotive fluid testing labs could give you an answer. My concern with Ethylene Glycol would be if there is a "side tank" used to have the boiler either heat or preheat domestic hot water. You would not want to risk cross contamination with potable water in the the event of a heat exchanger failure. Ethylene Glycol is toxic. Propylene Glycol isn't. It will be cheaper to use the proper fluid than risk having to buy a kidney. Or worse....Is there a way to identify what type coolant is in there?
Know of any that can analyze coolant?I'm sure one of the automotive fluid testing labs could give you an answer...
Google "truck antifreeze analysis" and you'll get hits for trucking industry coolant analysis.Know of any that can analyze coolant?
Google only turns up oil analysis companies, like Blackstone or Apex.
