Ordered a Glock 32 Gen4 today
Originally Posted By: john_pifer
[video:youtube]Check out tnoutdoors9's ballistics testing. He should probably be a BITOGer - that's how professional and thorough he is in his ballistics testing. He adheres to FBI protocol. This is amazing: Underwood Ammunition's loading of the 125-gr. Speer Gold Dot bonded, jacketed hollowpoint - 5-shot average out of the Glock 32, average of 1511 FPS and 634 lb-ft. That replicates the performance of .357 MAG, folks, out of a 14-round capacity autopistol. [youtube]http://youtu.be/iujNWfhUx4A[/youtube][/video]
Thanks John! I watched that video a few weeks ago. It is Very impressive! I actually already ordered some of that exact ammo! It's a screeming round.
I also ordered 100 of underwoods 125gr FMJ that is loaded the same, so I can get used to the hot round. I'm certainly looking forward to hearing the BLAST.
Every time I look at Underwood's site the prices are higher. Now I see the 50 round boxes are gone from a lot of ammo.
I agree, but they are still as cheap as factory loads in .357sig. You get 1500fps for the same price as the WWB 1350fps stuff at Walmart.
Originally Posted By: spk2000
I have a Glock 21 which is .45ACP and my buddy has a Glock 22 which is 10 mm. We swapped barrels and clips and it worked fine. It may work for other calibers as well so you could shoot cheaper rounds when you want if it does work. Not certain but could be worth checking it out.
The Glock 22 is a 40S&W pistol, the Glock 20 is a 10mm. It is also a magazine, not a clip.
$31.99... It just gets better
http://www.midwayusa.com/product/930292048/glock-magazine-gen-4-glock-22-35-40-s-and-w-polymer-black
I bought a few PMAG-15 GL9. They work great in the G19. I am a MagPul fan.
We've already been through this. Sig ammo is not $40 a box. $20-22/50 rounds for ball. Speer Gold Dots are $30/50 rounds.
http://www.sgammo.com/catalog/pistol-ammo-sale/357-sig-ammo
UMC $19/50
Gold Dot $28/50
HST $27/50
I ordered a few hundred rounds off of sportsmans guide @ $15/50 just now.
I picked up the Glock earlier and it's a beauty! I noticed it has a copper type of grease on the slide and friction points. Do you Glock guys run it like that first or clean that all out and use your typical Gun lube?
I normally clean everything i own before shooting it, and I lube it with Slip-2000, However the guy at my LGS said that i should leave the copper paste alone until i shoot a few hundred rounds and then clean it out and use whatever i prefer.
What do you Glock guys do?? Run the copper grease or remove it right away and put your favorite gun lube on the slide?
Shoot it. I'm sure they put the grease there for a reason and it wasn't to protect it from corrosion. I think Glock specifically says to leave the grease on there for a while.
I realize that as long as it is bought online. I already purchased ball online for $15/50 rounds earlier.
The point I was making was that the underwood stuff isn't any higher than Walmart ball. In my area $35 a box is pretty standard as a shelf price. One shop was even asking $49.99 for 50 rounds of Lawman
I was able to pick up a box of sig sauer 125gr in Louisville at cabelas for $25 a box I wanted to get a couple boxes to at least shoot some before my online orders come in.
Thanks for the help Hatt
Certainly appreciate it!
I take it you shoot .357 sig often?
Leaving or removing the copper ant-seize creates as much controversy as someone asking which caliber is best.
Glock says leave it. Dig a little deeper and you will discover there is nothing to clean in that area anyway; unless of course you find it necessary to visually keep your gun in like-new condition. Glocks run best almost devoid of oil. A couple drops of oil allowed to run down the slide rails is all that is necessary.
Check out page "46" here. https://us.glock.com/documents/gun_maintenance.pdf
Glock says to CLEAN and Lubricate the first time its used.
I disagree with devoid of oil. Makes no sense not to slightly lube the metal surfaces that slide over each other between slide and frame and a film on the barrel.
