I've bought a Motor Guard and oil cooler from Acewize (many thanks) and now I’m try to think of the best way of installing both of them.
The vehicle is a 1998 Nissan Frontier truck. The oil filter is a major pain to remove. It helps to be a contortionist to remove it. Also here in Dallas, hot weather is the norm.
I have bought a perma cool remote oil filter relocation kit but have not installed it. Acewize also threw in a remote oil filter mount but the oil inlet/outlet is on the wrong side.
I’m thinking of buying a perma cool oil sandwich kit and an oil thermostat to install the cooler.
My questions are:
(1) Do you think I should install the Motor Guard in line with the oil cooler
Pros
Easy to install/remove
Cons
Would the Motor Guard be hard to change because the oil will not drain down?
The Motor Guard has ¼ inch lines. Would this restrict my oil flow too much?
(2) Do you think I should tap off the oil pressure switch and return to a self tapping hollow bolt in the oil pan?
Pros
Greater flow to oil cooler.
No restrictions on oil flow.
Cons
I’m not thrill about punching a hole in my oil pan.
Opinions?
My questions are:
Pros
Cons
Pros
Cons
Opinions?
