$10 for 4 OEM pre-gaped copper plugs from the dealer once a year. I tried 3 or 4 different wiz-bang plugs and non ran as well as the old OEM stand-by's. 10 minutes and $10 a year is cheap insurance.
And that's where I'll argue with you. There should be no transfer if molecules at all, only of electrons.quote:
Originally posted by gtx510:
As I had understood it the arc is ionizing the molecules of the center electrode and depositing them onto the ground electrode.
With more protons (and therefore electrons) it seems like the center electrode would be more wear resistant.
Yeah, the whole positive/negative thing was an arbatrary choice by Ben Franklin (or so I'm told). He had a 50/50 chance, and he got it wrong, hence we have conventional flow and electron flow. If you read www.allaboutcircuits.com, they use electron flow for everything, so you get used to thinking of things both ways.quote:
What's always bothered/confused me is that electron flow is the opposite direction of current (they guessed wrong way back when).
And if you have the negative and positive of a coil backwards the sparks will jump the wrong direction and wear the wrong electrode.
I guess it makes sense that the electrodes would ionize oppositely with an opposite current.
quote:
Originally posted by javacontour:
Ok, Voltage, Resistance and Current.
V=IR
or Voltage = Current * Resistance.
Voltage is directly related to current and resistance.
