Originally Posted By: zimmerDN
Both rear rotors is much warmer than then front. This morning the rear rotors were hot to the touch and the front ones were cold. Driver side is still hotter than the passenger.
I wonder if its the e-brake cable not completely releasing. How can I tell? The rear wheels did spin when I had the wheels off the ground but I am not sure how well they are suppose to spin.
To check if the parking brake cable is releasing properly, you have to take the wheels off and spin the hub by hand. With the wheel on, you have very little feel for the amount of drag from brakes. For example on my Mazda I can spin the hub just by grabbing the wheel studs, the hub should not spin freely though, there should be some drag from the brakes. This way you can easily tell which wheel drags more. If one side takes quite an effort to spin, that's the problematic side. Inspect everything there.
