One bottle; two applications-- is this ok?
Bay Area, CA
I had two bottles (24 ounces) of Auto-RX.
I used one bottle (12 ounces) in my '01 Integra-R.
I have one bottle (12 ounces) left.
For engine applications, you're supposed to use ((engine oil capacity)*(2))+2 = Amount of ARX needed in crankcase.
I have a 4.2 quart sump, which makes it about 10.4 ounces to use for the clean phase.
However, I also wish to do a transmission application. This calls for 1 ounce of Auto-Rx per quart of MTL. I have a 2.1 quart fill limit, so I'm supposed to use 2.1 ounces of Auto-Rx.
This leaves me in a bind, as this would require 0.5 ounces of Auto-Rx that I don't have.
I know I'm being anal, but which one should I skimp on
Yeah, that was my initial thought. Cleaning the transmission is a one-time deal, so I may as well not skimp out on it. I can clean my engine with Auto-Rx any time, and plus, percentage-wise, skimping on the engine per 0.1oz is less impactful than on the transmission.
I don't understand how the transmission can get dirty, so I don't know what gains I can hope for. The transmission just gets metal shavings which the magnet picks up, right?
What benefit do transmissions have from Auto-Rx cleaning?
Will clean the bearings, then the larger components allowing more EP adhesion and better bonding post cleaning. Will have a helpful cleaning effect of the very fine silt in the < 5 um range well as abrasives in the
TD
Awesome information as always Terry.
Thanks!
I'm debating whether to do 100% Redline MTL or 50% Redline MTL and 50% Redline MT-90.
I'll look for other Honda users experience, unless you have a recommendation? I drive quite spiritedly on daily driving, and it will see autocross and light track use.
Logik, if you can hold your horses for a few more "days" there will be some of the finest ( affordable) lubes introduced by a company somewhere in the Midwest US that will blow away whatever MTL's you have used before. They actually have a formula exactly to fit the blended RL brew you are asking about.
We ran a recently posted developmental formula in a Nissan Transaxle with good results.
They also disclose more than any other company I have seen about what they use for components in the products, something BITOG folks will appreciate.
