Ok well when i got my First 2006 Subaru Impreza N/A in 2011, At that time I did a bunch of research and found that the Blue Honeywell OEM's had a big recall and that Purolator and Wix filters were the top pick at that time. Subaru Spec'd a 23psi BPV, the Purolators had a 14-18psi BPV and the Wix 8-11psi BPV. I opted to use the Purolator's as they were available at Walmart and less $$$.
Then Walmart switched to Fram and cleared out there Purolators for under $4. I bought a whole bunch and have been using them for the last couple years. The old car had a POS engine and i didn't care.
But 2 weeks ago I picked up a nice low mileage 2007 Forester N/A that has been kept very well and i would like to keep it that way for a long time.
Today I was wandering though a Walmart I dont usually go to and find a shelf full of old stock Purolators for $3.88. I couldnt remember the part number so i pulled up purolator's site to find they now specify a new L14615 supposedly with a 23psi BPV. At first i was confused but after doing some fresh research Purolators are now "tearolators" and have lost there reputation completely. it has me a little leary of my stash of filters
So here are the main questions:
1. I have about 15 of these older L14612's, Are older L14612's dated from 2012-2013 gonna be better construction/quality then newer "Tearolators"?
2. Should I find a new home for these and invest in some Napa Gold/Wix filters?
3. Would you worry about the change/update to the BPV from 14-18psi to subaru's spec of 23psi on the new filters?
