Hi,
I need to replace oil in a Jeep JK with 545RFE Auto transmission.
I bought many bottles of Royal Purple Max-ATF but looking at the label on the bottle I realized that I got the "old" Max-ATF that was improved starting from Sep 2007.
I need your help to know if the old Max-ATF meet the ATF4+ specs, here follow the old and new Typical Properties.
Thanking in advance for any advice.
Old Max-ATF Typical Properties
Viscosity:
cSt@ 40° C 32.4
cSt@100° C 7.4
SSU@ 100° F 272.8
SSU@ 210° F 63.2
CP @-10° C 568
CP @-20° C 1200
CP @-30°C 2868
CP @-40°C 7934
Viscosity Index 197.5
Flash°F 450
Fire°F 490
Foam Test:
Sequence I 0 ml/ 0 ml
Sequence II (4sec) 10 ml/ 0 ml
Density:
Specific Gravity @60°F 0.8358
Copper Corrosion:
3hrs.@210°F 1a
New Max-ATF ypical Properties
Viscosity:
cSt @ 40°C 32.5
cSt @ 100°C 7.5
SSU @ 100°F 164
SSU @ 210°F 51
cP @ -10°C (14°F) 332
cP @ -20°C (-4°F) 664
cP @ -30°C (-22°F) 1491
cP @ -40°C (-40°F) 3852
Viscosity Index 210
Pour Point -60
Flash °F 450
Fire °F 490
Foam Test:
Sequence I 0 ml / 0 ml
Sequence II (4 sec.) 10 ml / 0 ml
Density:
Specific Gravity @60°F 0.838
Pounds/Gallon 6.98
Copper Corrosion:
3 hrs. @ 210°F 1a
Viscosity:
cSt@ 40° C 32.4
cSt@100° C 7.4
SSU@ 100° F 272.8
SSU@ 210° F 63.2
CP @-10° C 568
CP @-20° C 1200
CP @-30°C 2868
CP @-40°C 7934
Flash°F 450
Fire°F 490
Foam Test:
Density:
Copper Corrosion:
3hrs.@210°F 1a
Viscosity:
cSt @ 40°C 32.5
cSt @ 100°C 7.5
SSU @ 100°F 164
SSU @ 210°F 51
Viscosity Index 210
Pour Point -60
Flash °F 450
Fire °F 490
Foam Test:
Density:
Pounds/Gallon 6.98
Copper Corrosion:
3 hrs. @ 210°F 1a
