Old power washer, new life
The Garden State
My 10 year old Troy-Bilt power washer, bought new in 2005 was used a lot early on then it sat in the garage for a number of years unused. Last year I replaced the pump with an AR as the original FAIP pump no longer worked properly. While the engine ran it was not smooth and smelled of fuel. The engine is a B&S 4.5 HP. I replaced the plastic carb with a replacement plastic B&S carb and it runs so smooth now. The AR pump cost $110 and the carb was $23. This is less than buying a new one with even cheaper made dubious parts. Shop the internet for parts.
Whimsey
They hawk the motor brand on pressure washers but never the pump brand as few would know a good vs bad. I have recently seen Craftsman pressure washers using AR pumps.
But in reality your not going to get a good pressure washer if its a vertical shaft engine.
Top name pump manufacturers like Comet do not even make pumps for vertical shaft engines.
That being said, for many people a cheap pressure washer is all they need (electric or gas).
For what I use it for that's all I need, occasional use. I'll take care of it this time by using the B&S pump saver and emptying the carb before I store it.
Whimsey
Occasional use it will be fine. As you found out, the engines are low hour units and will last a really long time usually. Pumps take a dump, but just throw another $90 eBay special on it and you're good for another 5 to 10 years.
If this is a flat head Briggs, tighten up your head bolts as they tend to come loose on pressure washers. Might even be a good idea to wire wheel the carbon off the top off the piston/valves and replace the head gasket.
Thanks for the tip. It is a flat head B&S
Whimsey
say I have a couple of different briggs engines from mowers etc, but no gas pressure washer, could I easily add a pump and get a washer? What characteristics of the engine would be important?
I have a Karcher 585 electric washer but it would be nice with a gas one too... especiallys if it's "homegrown"
Shaft size could be different and pressure washers run at 3400-3600 rpm while mowers run at 3100 rpm.
ok. interesting. RPM will be easy enough to set a bit higher, and if I could find a pump that would have the same fittings as the Karcher I would be set.
So, now I have a new project after the chainsaw+italian winch thingy!!! Great!
It would be cheaper to buy a used pressure washer from the classifieds than to try and convert an old lawn mower engine. You need a cast iron flywheel, pressure washer pump, carburetor, pressure washer cart, hose and nozzles. By the time you buy all that you could have bought a nice used one or a new one.
