Just sharing my old faithfull story.
When i moved into my current home (97) my grandfather told me there was a old pushmower in the garage. When i needed to mow that spring i went out and found what i have named "old faithfull" . In 97 the pushmower was beat up, the wheels were a little off center and only half the cables operating the choke, gas, ect were working properly. Well for approximately 3 years i used that mower and never changed the oil. when i hit my mid 20's (age) i got a little more responsible and started changing the oil every other year. Well starting about 4 years ago when i turned into a maintence nut i started changing the oil every year on old faithfull. I should mention ive never purchased oil specifically for the mower, it always gets whatever is leftover from auto bottle oil changes, only 4 years ago did i start making sure i was dumping 5-30 in it. Well lets fast forward to today, Old faithfull's wheels are down right crooked, the cables have been cut and are long gone. this mower is no spring chicken. I got old faithfull out after doing some re-seeding in the back yeard and decided while the weather was good to go ahead and change the oil. I never started the mower, just pulled the plug and let her drip drain for a half hour or so, then refilled with a leftover bottle of valve syn-blend 5-30. I held my breath and pulled the rope. FIRST PULL, old faithfull fired right up.. this will be the mower that my kid will end up with in 16 years, i can feel it
