Originally Posted by Fordiesel69
IF, and only IF you do highway runs to burn off any fuel dillution or water vapor, then I run all of mine 3 yrs, 3k miles and never had an issue or bad oil sample come back. There has been a few times it took all 3 yrs to get 3k miles and the filter just started to get surface rust on its unpainted surfaces.
It is not necessary to drive on the highway to get the oil up to full temperature. The key is engine run time... most engines will get to full temp in 5-8 minutes, depending on ambient. But the oil can take up to 20 minutes to reach 180F. That's why it's recommended, if you are doing a trip with multiple stops (like running errands around town), drive the longest leg first.
