This thread is about which OILS HAVE or DO NOT HAVE foil seals.
I want to start a threads about which oils HAVE or DO NOT HAVE a foil seal. This is so people can know which oils have a foil seal before they purchase, because there have been incidences where the cap ring seal has been defeated and used fluid has been returned and restocked to be sold as new. I personally found two one-quart oil bottles at a Walmart that you could tell that the paper label had been contaminated with dirty used oil and wiped clean. I pointed them out to the store manager and explained that most likely those bottles had been refiled with used oil and returned, and he removed them.
This could also serve to encourage manufacturers to use foil seals.
Recently there was a thread "Pennzoil 5w20 5 qt - something very wrong" about oil that apparently did not have the foil seal and somehow was not proper.
____________________________________________________________________
I will start off this thread with comments about:
Castrol European 0W-40 in the black bottle, it DOES have a foil seal.
