oilfilterdata.com not offering AC Delco part numbers
I've also noticed they don't have the Purolator Boss filter listed, but they show a "Purolator Synthetic", which oddly enough has a worse beta rating than the Pure One. Pure One is 99.9% @ 20 microns which translates to a Beta rating of 1000@20, Synthetic is 99% @ 25 microns which is a beta of 100@25....
The PureOne isn't rated at 99.9% @ 20u anymore - it's 99% @ 20u. I went to the Ultra (wired backed media) many years ago because Purolator had media tearing issues.
https://user-yckgqj.cld.bz/Purolator-2019-Master-Brochure
"Ultra" as in Fram, or AC Delco?
The Fram Ultra (99% @ 20μ). I use to use ACDelco UltraGuard om my Z06 when they first came out, but I think they aren't as efficient now as they were then back around 2005.
Thanks Zee,
Much like the P1 isn't as efficient now, either.
My original post was to ask why oilfilterdata.com won't show AC Delco products. They do show PF13, but give no efficiency data. I read in another thread where OEMs don't really want you to know how (in)efficient their filters are, do you have any info on the ACDelco UltraGuard?
Having a porous filter with marginal 30micron efficiency will not plug up as fast, seldom go to bypass, and probably filter enough to keep the engine running until 100K, which is about all they care about, IMHO. They can boast long OCIs as a selling point, and once the warranty runs out, you are on your own.
Is there any data on filters' 10 micron efficiency? I have been trying to find data and not having much luck.
Been using the P1 better than 10 years now, it is inexpensive for the filtration it provides. I understand it is probably prone to early "filling up" due to its efficiency, so I rarely let the oil or filter go much past 2K. Also using the oversize option to expand surface area and keep deltaP low. Advance Auto still sends me the old yellow filters (the PL24011) from their Bakersfield warehouse, you think those are better than the new blue ones? The date codes for the yellow ones are in 2015. When H+M took them over, they went to blue, correct? You think that's when the efficiency dropped?
I've seen the "hockey stick" efficiency curves where the filter loses efficiency as it fills, possibly due to already caught particles escaping due to flow patterns changing, or just higher deltaP dislodging them. The new Purolator Boss cutaway pic is impressive, the media is thicker, has an inside layer that looks as if its capture and hold ability would be way better. It is, however, 55% more expensive ($13.99 as compared to $8.99 for the P1). It's efficiency is put at "99+%", I'm assuming they mean @20microns, but that is not stated. Any thoughts?
Thanks,
I forgot to address this in the last reply. Do you think the tearing issues were related to extended OCIs where the media loads up and the added stress rips it? Have they fixed this issue? Did the H+M takeover reduce efficiency to address this?
The root cause was not caused by extended OCIs because most of the reported torn filters were not used beyond the recommend period. There were even a few that showed tears with less than 2000 miles IIRC. And certain filter models seemed to be more susceptible to tearing, it wasn't across the whole line. Did you ever cut any of your used P1s open to inspect?
Any oil filter should be able to take the delta-p level across the media equal to it's bypass valve setting. If it can't, then it's not designed correctly. The main cause of the tearing media was brittle media combined with wide pleat spacing at the seam area. If it's totally fixed is bard to say,but we still see reports/posts of Purolator made filters with media tears.
The current efficiency ratings haven't changed much (ie, PureOne went from 99.9 to 99% @ 20μ), and wouldn't really make any difference. Besides, the PureOne wasn't very restrictive in the first place.
Have you seen the cutaway of the Boss? Looks like it would hold more particles more securely with the sandwiched media?
I have cut them open in the past, not done that in some time, don't remember seeing any tearing. The old yellow P1s that Advance Auto is sending me for PL24011 has me worried that the media might be aged. It is synthetic blend, maybe the cellulose portion could be suspect?
The Boss nylon mess (I believe) backed synthetic media, so it shouldn't have any issues. I don't recall seeing any Boss filters being torn, no surprise with the mentioned construction. However, the Boss isn't as efficient (99% @ 25u, which isn't too bad) if that's something you're after.
Here's a spreadsheet member Stu_rock (IIFC) made up when all the tearing was going on. I see only one 24011 (on line 46) in the list, so either not many people used and cut those filters, or they weren't; susceptible to tearing. Link ---> Torn Filter Spreadsheet
The spreadsheet only captured I'd estimate half or 1/3 of the torn filters reported here ... it was not all encompassing.
Yes, it is nylon mesh, I found a video of one cut open, from the advertisement I thought it was more filter media.
I remember seeing on one of the Purolator ads that the Boss is rated 99%+ for 20 microns with an asterisk. The asterisk footnote was that spec is only up to 10,000 miles. The "regular" lifespan is 15,000 miles. I think it was one you posted.
See post #3 and #5. The Boss is rated at 99% @ 25 microns. Still not bad IMO.
I'm reading the footnotes: the asterisk is for the "Ideal Oil Match" and the cross is for "Dirt Holding Capacity". So the way I read the cross footnote is the L and PL models can hold the stated amount of dirt at 20 microns, and The PBL can hold 27g at 25 microns. The "Dirt Removal Power" just has "TM" (Trademark). It does say 99+ for the PBL, but doesn't give a micron level.
So..... If the PL or L were tested at 25 microns, would their Dirt Holding Capacity be as high as the PBL? Is the PBL 99+ efficient at 20 microns, but cannot hold 20 micron particles very long? Is the DHC of the PBL lower for 20 microns? These are all rhetorical questions, not intending to dig at anyone.
I think the PBL numbers are less efficient because they base them on 15,000 miles, a selling point to justify the higher price, IMHO. I still can't find the brochure that stated the PBL was 99+ efficient @ 20 microns, but only for 10,000 miles (it was a footnote). That would make sense, due to the filter losing efficiency as it fills. Maybe they changed these specs due to a higher bypass valve setting? The higher deltaP would loosen smaller particles from the PBL above 10,000 miles?
As I said, I can't find the brochure that stated that, not sure whether I found it on a Purolator site, or from a post on here, or another forum.
ZeeOsix, can you look through your files and see if you have that?
Thank you for finding and posting this, however the spreadsheet only shows "Failed Engine Oil Filters", a majority of them failure not specified, and those that were specified were mostly ADBV issues. Only a few had media tearing issues. The two that collapsed were cartridge filters, possibly the vehicle's bypass not working?
Once again, all questions and points are put out for discussion, just looking for information ;-)
The holding capacity and "at 25 microns" are not related - I think that's a typo by Purolator. The footnote in the chart in post #3 is really saying that the Boss (ie, PLB) is 99+% efficient at 25 microns. Look closely at the same Purolator info in the link below ... you can see the footnote asterix next to the "TM" in the "Dirt Removal Power" (ie, efficiency" info row). Also see post #16 below.
https://www.pureoil.com/en/do-it-yourself/oil-filters/oil-filter-selection-guide/
The filters that have no notes in column K were torn. Believe me, the majority of those filters listed are there because of media tears. You can go back and find every posted torn filter thread if you want to go back and search the board around the 2014-2016 time frame.
Thank you for the research, these are current (2021) specs, the one I saw apparently was older, I presume. So they tested only one size, 30001, with the ISO 4548-12 and extrapolated those results across all sizes?
So the 2 yellow filters I received in size PL24011 mfg. 09/23/15 are probably suspect? Advance Auto is still shipping these from their Bakersfield warehouse. I see from your thread from 10/03/14 the ones to avoid are dated 06/12 to 11/14. Btw, I printed that table way back and use it for reference when I order filters. If it was your post, a belated thank you!! You think I should attempt to swap them out for newer versions? The PL22500 I also received are dated 02/29/20, must be a more popular size.
I just realized that most GM (correct me if I'm wrong) have the bypass valve in the filter mounting base. The PL 24011 has no built-in bypass valve could this be a cause of tearing? I have not heard of a valve sticking closed, but I have had one that was not working. The plate was no longer securely mounted, and had minimal spring pressure. I got a new one, spring pressure way stronger. This in a 3.1 V6 Camaro, I had to take the motor mount off to swap out the mount plate, IIRC.
AH HA!!!!! I found it!! It is in an Amazon description, don't know how old, but this is where I got that information.
