I seek your wisdom, the search function is balls, at least when I try...
2010 Crown Victoria, 95k miles. Last OC was Motorcraft semi synth 5W-20, 3k ago. Motorcraft filter too.
Started it up yesterday for the first time in colder (below 45*f) weather. First time below 45* in this car ever, purchased it in the summer. The car kinda knocked a bit, made a sound lower that a typical knock noise. Subsided after I drove it a quarter - half a mile.
Would you / should I try a fill of 0w-20 to see if it helps? Has anyone had a similar situation occur in their vehicle? Did 0w help at all? I have not spent enough time reading about weights and specs on here, I know that. I know if I spent hours searching and reading, I'd find an answer, but my family will not let me do that today.
Simple: Will 0W-20 in a car spec'd for 5W-20 help with a low knock noise in cooler weather (on startup). Are there any advantages to using 0W-20 in a 2010 ford 4.6? What would you do if it was your vehicle?
TIA Guys!
TIA Guys!
