Originally Posted By: dan765
Originally Posted By: gregk24
The First number is the winter rating. If it's just sae 20...sae 30 etc, it's just a straight weight oil
So how is it different from the multi-grade oils in terms of thickness/thinness.
Using straight 10 weight, it is thicker or thinner than 5w-30 or 10w-30?
You're doing what almost everyone does when they first start trying to think about multi-grade oils: thinking of it as it pours out of the bottle and trying to decide whether a 10w30 or SAE 30 should "look thicker" and assess how they perform in the engine accordingly.
Forget that.
The oil viscosity rating is the SECOND number. So a 10w30 and an SAE 30 and a 0w30 and a 5w30 are ALL 30 grade oils. What that means is that at a standard temperature intended to more-or-less correspond to the OPERATING temperature of the oil (in other words, hot!), they are all within the range of viscosity that the SAE designates as a 30 weight oil. They're all about the same when hot.
So why are they different? Well, what happens when you cool each one of them off, going DOWN in temperature from that operating temperature where they are all the same. This is where they become different. The lower the FIRST number, the LESS the oil is allowed to thicken up as it cools down to the sub-freezing point where the cold characteristics of the oil are measured.
So turn your thinking upside down. Start with the oil HOT, which is what the engine experiences most of the time its operating. The 2nd number indicates how thick it will be, the first number indicates how much thickER it is allowed to become as it cools. A 0w30 oil changes less as it cools than a 10w30 is allowed to. That's why, contrary to most people's first impression, there's nothing at all with running a 0w30 in Death Valley towing a trailer in the middle of summer. Its STILL a 30-weight oil, assuming its formulated well enough that it doesn't break down (and most modern oils are).
