It hit 105 today in Tucson, or so my thermometer said. Each year as summer approaches I wonder about the effect of the outside air temperature on the temperature of the oil in the engine.
My bike is an '07 Goldwing, which is water cooled. The cooling system works just fine -- the temperature gauge is consistently just below 1/2, and the fan comes on only occasionally.
Here's my question -- I hear about the effect of "extreme heat" on oil, and I wonder what exactly that means ... particularly for a water cooled bike operated normally -- that is, no excessive idling in traffic, no towing a trailer, no aggressive redlining of the tachometer.
My guess is my oil temperature -- whatever that is (the Wing does not have an oil temperature indicator) -- doesn't really vary that much, be it 90 degrees outside or 110 degrees outside. My guess is as long as I'm moving down the road and the air is flowing through the radiators (yes, plural ... there are two of them), my oil temperature probably stays relatively stable, and below "extreme."
And my ultimate question is this -- Is there any reason to believe Tucson summer heat really calls for a synthetic? Or would a good, modern conventional oil do just fine in a water cooled bike in the Tucson summer?
