Oil temp gauge with Amsoil By Pass
Sarasota, FL
I have installed an Amsoil BMK-13 By Pass filter set up and am wondering of anyone has added an oil temp sender to this setup.
I am thinking that the oil sample valve location would work.
Opinions and ideas .....
Adding a temp sender at the petcock location should work fine Since the BMK-13 is machined out of aluminum (high heat transfer coefficient) and that port is close to the oil stream, you'll get pretty accurate oil temps.
Keep in mind that a sender mounted there would measure the temperature of the oil going into the engine. The oil in your oilpan would be a little hotter.
Does the Amsoil unit come with a pressure gauge? If not, you can grab one from Carquest (mechanical sender) for $10.
quote:
Originally posted by mjo:
Does the Amsoil unit come with a pressure gauger? If not, you can grab one from Carquest (mechanical sender) for $10.
The question was about an oil temperature gauger, not a pressure gauger. No, the Amsoil unit does not come with a Pressure gauger.
I plan on using a digital oil temp gauger from Dakota Digital ( http://dakotadigital.com/ ).
I don't know how effective it would be.
I would rather have the oil temp taken from the Oil pan.
Punch a whole about 1/4 way up on the side and tap it in there. You will have a more accurate reading of the entire oil, not just a mere 10% at any one time.
I would bet taking the temp from the by-pass filter could be several if not 10's of degree's cooler than the pan itself.
