Hello,
I'm Wolf from Italy.
Car is Toyota Celica GT four, engine is a modded 3SGTE ( 430 awhp - 588.2 Nm torque ).
According to my oil clearance ( 0.045 mm ), oil used is Motul 300V 10W-40.
Engine is newly rebuilt, 1500 kms old.
After 6 rounds in a local track ( ambient temp was 5 deg. C. ), I get 125 deg. C. ( 1740 F ? ) and a oil pressure of 2.5 bar above 3000 rpm ( sensor is in the head ).
For the temp, now I have the stock water/oil cooler plus a small air/oil cooler: it seems that I have to buy a bigger cooler and move it in front of the water rad ( now is behind the bumper, where there was the side-marker ).
For the pressure... isn't it too low ?
Talking with other high hp Celica owners, it seems to be a normal value, but it doesn't tranquilize me a lot...
At cold I'm getting over 6 bars at 2000 rpm.
Shimming the relief valve shouldn't change anything because at that pressure I think it's not open.
Lowering the oil temp will help me with the pressure ?
Any comment/advice ?
Thank you !
Thank you !
