I have a Yanmar 6LY 440 hp marine diesel engine. It is a 6 cylinder in line common rail with a displacement of 5.2 ltr. Max rpm is 3300. It is filled with 19 ltrs of Mobil Delvac MX 15w-40.
I noticed that after longer periods of cruising at 70-75% load with a corresponding rpm of abt 2800 that if reducing to idle (600 rpm) the oil pressure drops to 1.4 bar before gradually increasing ro about 2 bar as the oil cools down. The cooling water temp remains stable at 74-75 deg C no matter how hard I run it. So I measured the surface temp of the oil pan with an IR thermometer while at 75% load and measured 103-105 deg C.
Question: Does anyone have experience with how much heat is lost when measuring this way? I am a little concerned about the oil temperature and wonders if I maybe should start using the synthetic Mobil Delvac for possible better temperature abilities.
Regards from Norway
Regards from Norway
