5w30 should be great for the Chevy; 5w20 is the ticket for the Honda, as you've found out. Synthetic or conventional, your choice.
I think most of those great reports were for 4 cyls, this is a V6. Besides Mobil 5w-30/10w30s are on the thin side to start with, so for this climate, we're splitting hairs. I stand by my choices for this climate and vehicles if you wanted to use one oil for both vehicles.quote:
Originally posted by mikemc:
For the Honda I would say Motorcraft 5w20 given it's great UOA results.
I certainly would myself . I'd pick up a 5 gallon pail " $4.70 a quart " of Synergyn 5w-30 and run the Honda to 10k miles if it see's quite a bit of hi-way , the Chevy to near same with a filter change in the middle of the interval where you live again with some hiway driving .quote:
Originally posted by Bulldog:
Could I run 5W30 in both vehicles?
Actually many were V8's and V10's in Ford trucks.quote:
My bad. I was referring to great reports on HONDAS.quote:
I have an 04 Suburban with the 5.3. I put in Schaeffer's #703, a 10W30 blend at 1.5k and at 5k. I used a Delco UltraGuard 44 both times. I get no clatter. Overall, the oil seems to be doing fine. I'm at 5.5k now. May do a UOA later. I plan on 5k changes with the Schaeffer's.quote:
I changed out the Chevy at 1,000 miles with Penn 10W30 and then switched to 10W30 Amsoil at 3000 miles. I am noticing valve train clatter (not CSK) for a short time after start up. It did not do this with the original oil. .... Any recommendations? Could I run 5W30 in both vehicles?
