Okay, I just bought an 05 Land Rover lr3 with 65k miles. It has been serviced since new at the local land rover dealer. They did oil changes every 7500k with the recommended conventional 5w30 castrol. I am not a guy who gets minor service done at the stealer. I am wondering what you guys think on what oil and filter to use. The book calls for 3,000 mile changes but is kind of indirect about it. It says and I quote..
" The oil consumption of your engine is influenced by many factors. New engines reach the normal value only after 5000km (3000 miles) Under high loads you engine will also consume more oil."
It says nothing else about oci
It then says
"Recommendations for all climates and conditions
NOTE: Recommended oils are complete in themselves and additives should NOT be used
NOTE: It is essential to change the oil MUCH more frequently if the vehicle is operated under severe conditions.
Use only oils Certified for Gasoline Engines by the American Petroleum Institute (API). To protect your engine's warranty, use and SAE 5w/30 oil meeting specification WSS-M2C929-A (GF4)"
That is straight out of the book guys. I also plan on keeping the car for the long haul!
Thanks
Jim
It then says
Thanks
Jim
