Oil suggestion for 65 Chevelle SS?
PA
The Chevelle is a L79 car, the high 350 horsepower 327. It has a healthy hydraulic cam, not sure if it's stock. Previous owner ran Mobil Delvac 15w40.
I'm looking for oil that's more cold start friendly. I just bought it and I'm expecting alot of cold starts in the next few months.
I don't know any specifics about the engine. I believe it has been rebuilt, atleast I expect the heads were since they look new inside the valve cover. The owner died unexpectedly and all useful knowledge went with him, he'd owned the car for almost 50 years. This SS has a 4 speed and 12 bolt with I'm guessing 4.11 gears. It will be turning some RPMs and wants to rev.
Here's a picture from earlier. Replaced the master cylinder and all the wheel cylinders tonight. (Master and couple wheel cylinders were leaking)
It has 14" Cragers and a matching spare. Not my taste. The SS hubcaps are in the trunk. I haven't been able to locate the steel wheels yet but will likely be going to steels with dog dishes.
Are you going to drive you car in freezing weather?
Definitely.
The Chevelle is a L79 car, the high 350 horsepower 327.......Previous owner ran Mobil Delvac 15w40.
I would stick with the Delvac 15W40, but if you need better cold temperature starting then go to Mobil Delvac-1 5W-40 synthetic.
Other options would be the Shell Rotella or Chevron Delo equivalents to the above.
You could also consider the high performance Euro oils that carry ACEA A3/B4 and OEM specs like MB 229.5 and Porsche A40. Typical oils would be Mobil 1 or Castrol Edge or Pennzoil Platinum Euro in either 0W40 or 5W40.
a Euro 0-40 or even a high ZDDP 5-30 like RP HPS
You don't have cats to worry about (not that it should be a worry) so you can run anything you want really
