Oil specs comparisions 2005
this is old data, 2002 era. Most of these are probably obsolete; and those that aren't would be revised by the current numbers above.
code:
Castrol
100C 40C VI HTHS CCS Pour Flash
Syntec
0w30 10.0 54 175
5w30 9.7 53 171
10w30 10.0 58 159
10w40 13.2 89 148
5w50 17.5 110 175
20w50 18.5 154 135
Castrol Syntec Blend
5w30 10.8 64 160
10w30 11.5 79 138
10w40 15.9 111 152
20w50 20.7 180 135
Castrol High Mileage
5w30 11.9 70 167
10w30 12.0 78 149
10w40 15.8 108 155
20w50 20.3 171 138
Castrol GTX
5w20 8.8 50 158
5w30 10.7 6s3 160
10w30 10.7 72 142
10w40 14.2 100 150
20w50 17.6 153 128
Castrol Heavy Duty
Sae30 11.5 97 106 ----- +22 446
Sae40 14.0 129 106 ----- +22 446
Castrol other
Rxsuper 15w40 14.3 110 132 ----- -33 446
Gpracing sae30 10.4 82 110 ----- +5 428
Gpracing sae40 13.5 119 110 ----- +10 450
Gpracing sae50 18.5 204 110 ----- +14 470
GP motorcycle 20w50 17.2 153 123 ----- -6 440
GP motorcycle 70 27 350 106 ----- +14 496
can't forget this one,
Viscosity for 100C and 40C were min max numbers, so the single number listed here is the average.
code:
Schaeffer Oil
D445 D445 D2270 D4683 D5293 FTM7916-203 D92
100 micrmoly 5w30 11.25 62 159 3.2 6000, -30 -41 424
306 micrmoly 10w30 11.25 69 148 3.2 5800, -25 -38 446
106 micrmoly 10w40 13.8 94 150 3.46 6884, -25 -38 417
D97
107 molyx200 sae30 11.65 107 106 3.9 ---- 0 460
110 molyrace 30 11.25 91 102 3.5 ---- 0 455
110 molyrace 40 14.75 175 100 4.0 ---- +10 465
110 molyrace 50 18.75 225 102 4.0 ---- +20 500
D2602
156 molypuresyn 5w30 10.6 55 185 3.8 2100, -25 -60 465
D5293 FTM7916-203
151 molyx200 15w40 15.25 111 140 4.08 5392, -2 -41 442
191 molyrace 20w50 19.75 162 125 4.47 6575, -20 -33 450
700 supreme 15w40D 15.0 118 145 4.3 4877, -25 -41 457
701 supreme 5w30 11.0 50 180 3.5 5073, -30 -41 448
703 supreme 10w30 11.0 66 150 3.5 4500, -25 -41 444
705 supreme 20w50 18.25 148 140 4.55 2950, -15 -41 465
D97
702 supreme 30w 12.0 104 105 3.5 ---- -10 455
702 supreme 40w 15.0 144 105 3.8 ---- -5 500
[ January 21, 2005, 12:15 PM: Message edited by: 1 FMF ]
this is the last one,
Transmission & Gear Fluids
code:
100C 40C VI HTHS Brookfield Pour Flash
D445 D445 D2270 D97 D92
Pennzoil Synchromesh 9.08 41.6 208 -50 385 dated 3/2000
RL D4 ATF GL-4 7.5 34.0 198 52, -40 -76 437 dated 2/2004
RL hi-temp ATF GL-4 10.0 53.9 172 175, -40 -60 460 dated 2/2004
RL MTL GL-4 10.6 56.2 183 120, -40 -58 450 dated 2/2004
RL MT90 GL-4 15.6 90.0 185 320, -40 -49 465 dated 2/2004
RL 75w90NS GL5+ 15.6 94.5 176 400, -40 -49 430 dated 2/2004
RL 75w140NS GL5+ 26.9 179.2 188 1200, -40 -49 420 dated 2/2004
RP Synchromax 7.7 35.3 196 -40 450
RP Max ATF 7.4 32.4 197.5 ---- 450
AMSOIL ATF 7.7 36.8 182 1092, -20 (7454, -40) -67 424
Schaeffer #204s ATF 7.65 35.25 194 2.6 1010, -20 -60 425
Mobil-1 Synthetic ATF 7.6 34 199 5190, -40 [=D5293] -65 456
Mobil-1 Mercon V blend 7.5 ---- ---- 10500, -40 -67 403
Mobil-1 ATF+3 7.6 33.7 200 18000, -40 -44 356
Mobil mult-purp ATF 7.6 38 176 16200, -40 -59 359
[ January 21, 2005, 12:12 PM: Message edited by: 1 FMF ]
