I bought a 99 camry with the v-6 and 90k miles and then heard about the sludge problem. Took off the front valve cover and NOTHING (no sludge). It remains a mystery that some have problems and the oil service is generally the same.
Not quite accurate. True, the older cars had shorter gears, that was to compensate for no overdrive. With an OD trans you can run much steeper gears and keep your RPM's way down. On that note my car has 3.08 gears from the factory and many others have even shorter gears. I do agree that pound for pound new engines work much harder than their older cousins.quote:
Originally posted by tdi jerry:
...THE ENGINES WORK HARDER THAN THE BIG BLOCKS LIKE I USE TO HAVE 1969 DODGE CHARGER WITH A 440 CU IN ENGINE WITH 375 HORSE POWER. THE OLD ENG TURNED LOWER RPM'S THAN THEY DO TODAY.THE REAR ENDS USE TO BE SOMETHING LIKE A 273/323 OR LIKE THAT...
JERRY![]()
Unfortunately, this is true for the newer manuals only, and that is part of the problem. My 2001 Passat manual explicitly says to use EITHER petroleum-based or synthetic oil, meeting at least one of 3 specifications, one of which is good old API SL.quote:
Originally posted by Ken2: The three brands had different causes for the sludging.
VW had sludging only in the turbocharged engines which did not use the owner's manual-required synthetic oil.
I wonder how many VW sludge problems arise from PCV problems. ...quote:
Toyota had the sludging only in two or three lines of engines where they had made some changes in the PCV or other otherwise minor details.
I wish I did. Since I have a 2.4L 4-cylinder, I THINK I am safe ...quote:
I don't know the cause of the Dodge sludge.
For those who do alot of short-distance, stop-and-go urban driving and don't have "problem" engines, oil change frequency is arguably more important than oil quality. PERHAPS these folks are better off with dino on a 3K mile OCI than synthetic on a 5K.quote:
A common factor here is that Americans feel a need for cheap oil and put no value on their time with 3000 mile or 5000 mile oil changes. European oil is much more expensive, much higher quality, individually spec'ed for each engine manufacturer, and has 10,000 to 20,000 oil drain intervals.
My answer...use a top quality oil that remains good for longer oil drain intervals. ... I'd feel equally protected using one of the other top quality oils.
Ken
How serious is your sludge problem? If it is not too late, Auto-RX may help. Does your car get mostly city driving? How is your PCV system? What brand of oil do you generally use? filter? Does your engine take the minuscule K-car oil filter, or a larger one? How big is your sump?quote:
Originally posted by max:
I just found out today that I have a sludge problem in my 2000 Caravan with the 3.8 engine. I have had the van since day one and have every oil change documented. The oil changes average approx every 3000 miles. I am aware of the problems with the 2.7 engine, but has anyone else heard of problems with the 3.8? This really has me upset and perplexed as I have been so careful with oil changes.
