Hi guys. I was wondering if anyone could answer this. Im far from a mechanic. My limit is pretty much oil changes at this point.
I was just putting my battery in, and changing my oil for spring on my 2013 mustang 3.7 six.
If i look directly at the engine from the front, I noticed 10mm bolts along side my left are showing oil seepage.
The ones toward the top aren't as bad as the ones below. Im not sure if that's because the oil would obviously gravitate downward or if the lower ones are worse.
The first photo shows the front of the engine and I flashed my light in the upper area.
The last photo is a view laying under the vehicle looking upward in the same area.
Should I re-torque these bolts, and if so to what?
Does anyone have any ideas as to what this issue could be?
Thanks again, and I know diagnostics is very difficult from just photos.
