Oil Sample Prior To Bypass Filter Install
Home
The factory 3/36 warranty is about to expire on my F150 Supercrew and I have decided to install bypass filters for both oil and ATF and I have a question.
Would a oil/ATF sample to test prior to the bypass install serve any purpose ?
It will give you a baseline against which to compare. It will let you know if there are any immediate problems.
If you are going to keep the same oil, it will show you if the bypass filter can clean up the existing oil.
