Hi guys,
I've recently been reading about the camshaft failures since the EPA mandated drastic reductions in the ZDDP levels in oil for gasoline engines.
I have three vehicles that I'm concerned about, and I'd like to get some recommendations.
Vehicle 1, 93 Suburban 3/4 ton 454 4x4, nearly stock but with Edelbrock emission headers, flowmaster exhaust, and K &N air filter. It is high mileage, with 225K miles. The original owner ran Mobil 1 10w30 in it up to 150K miles when I bought it, and I've been running Mobil 1 ever since. Since it has a flat tappet cam, I'm thinking about switching to Mobil Delvac synthetic, 15w40. The alternative is to continue to run Mobil 1, but add the GM Engine Oil Supplement ($10/bottle). Has anybody got any suggestions?
The next car is a 96 Suburban 454 3/4 ton 4x4, bone stock with 110K miles. The previous owner has run various 10w30 oils in it (never a synthetic). I'm currently running 10w30 Castrol. I'm thinking about running Shell Rotella 10w30 conventional oil.
The last car is a 74 Trans Am with a fresh 455. I'm currently running Castrol 10w30 GTX, and I'm thinking about going with Valvoline Racing Oil or Shell Rotella 10w30 diesel oil. My oil pump is a 65 psi unit and oil pressure at 2000 RPM is about 65 psi, and at idle it's about 25 psi (measured hot). I will say the 455 in the T/A is new because it ate a camshaft lobe about a year ago, so I'm very concerned with the info I'm reading on reduced ZDDP levels.
I saw the charts posted by Stinky (sorry to hear about his misfortune). The levels of zinc and phosphates look high on most of the engines. Has anyone published numbers detailing how much ZDDP is contained in the various motor oils.
Last question: Should I add an additive containing moly to my oil?
Thanks for any info you can provide.
Mike
Mike
