For a pleasure truck, the 10/30 will be more than sufficient.
440: The Mopar B/RB engines sure do seem a lot more comfortable with the larger end of the rpm range. Very unusual for a big block, but not all that surprising given the engine design. Chrysler really put a lot of thought into that design. Compare it to the BBC and it looks really intelligent.
Shaft mount rockers, external oil pump, dry intake manifold, cartridge oil pump, front mount distributor.
The geometry of the engine was always very friendly to high rpm as well. Those 440 TNT engines would spool out all day long, with a conventional 440 bottom end. Same goes for the Six Pack. The short stroke 383 laughed at high rpm as well.
Where the Ford 390 was concerned, I don't think any of the FE engines ever had a problem revving out. We all know there were plenty of seriously high rpm FE engines built using traditional geometry in the bottom end.
I think to a certain extent, the BBC suffers from valve train stress as well. Those off kilter angles the pushrods have don't like big rpm either. Seen a decent amount of busted valve springs too, usually the forward intake valves. They should really stay at or below 4000 rpm constant, and never more than 4600 rpm intermittent from the factory.
The big bores and bearings are a good point, but it is worth mentioning the marine versions run 8-10 quarts. We have brought the iron levels down appreciably by using stouter oils, but does not ever match the small blocks.
I've driven the older Chrysler and Ford big block marine engines, and I felt they were better engines. Especially the high-nickel Ford 428. That thing is a scary beast, but most 428's were.
But of course the BBC is still a darn good engine when doing almost anything, but for dedicated high rpm, it's more comfortable with some key mods. It's undeniably the king of mod big blocks as well.
