With the reduction/elimination of ZDDP from oils and their "reformulations" lately, what would be your recommendations for these 3 cars?:
1) 1973 DeTomaso Pantera, 351 cu in Cleveland, 35,000 original miles, Sunday evening pleasure use. Original owner's manual specifies 20-50 wt oil. Does not burn any. Car is very rarely started or driven at air temp less than 50 or over 80 degrees F. One good Pantera specialist uses only Delo (400 I believe, which is 15-40?).
2) 1972 Ferrari Conventional 246GT. 2.4 liter, four overhead cams, 10,000 miles since rebuild at dealer. Does not leak any more with the Mobil 1 15w50 RED top in it now than it did with Castrol GTX conventional 20w50 oil. Same use/driving conditions as Pantera.
3) 1995 BMW M3, 3 liter engine with low-friction oil control rings and hence burns more oil than a typical Bimmer. Does NOT have roller cam followers. 144,000 miles, burns about 1 qt in 3000 -4000 mi of either 20w50 conventional or the Castrol High Mileage 20w50 in it now. With M1 red top 15-50 it burned about twice that much. Owner's manual specifies 20-50 for my Southern California climate.
With all the reports of engine failures at race tracks using M1 gold-top, elimination of ZDDP from almost all oils, etc, I'm so paranoid I don't want to change my oil until I know what I should use.
Thanks in advance.
Thanks in advance.
