I have a 1972 Steyr Puch Pinzgauer and am wondering if I should be using old fashion or modern oil in it. It has a 4 cylinder 2.5 liter air-cooled engine producing about 95 HP. It has aluminum pistons in cast iron cylinders, flat tappets, and gear driven cam. The crankcase is vented but not ventilated. I have an oil temperature gauge and the oil tends to stay around 200F. There are no valve seals
The lack of true ventilation in the crankcase results in some water condensation. This is noticeable as “white gunk” in the oil fill pipe but is never noticeable in the oil itself.
I recently had the engine apart and it looks clean with no oil related issues other than hardening of the 50 year old seals on the pushrod tubes.
The manufacturer in 1972 specified SAE10 in “winter” and SAE 30 in “summer”, both meeting MIL-L-2104B. Oil pan holds about 7 quarts. Specified oil change interval is 3,000 miles/100 hours.
Oil chat among owners has several themes. One is that changes to oil additive package to be catalytic converter friendly (reduction of ZDDP) makes newer oils inappropriate. Another is that synthetic oils cause more problems with oil fouling of plugs than mineral oils. A fair number of owners use an SAE 30 HDEO rated for compression but not spark engines.
.best regards,
Jimmy C
.best regards,
Jimmy C
