Oil Recommendation
FL USA
Need oil recommendation for 2001 Sport Trac 4.0 SOHC with 113000 miles.
Currently using using Kendall High Mileage 5W30. Has very minor oil drip.
Thanks JeepWJ19, there is so many oils on here I've been reading about maybe
there was one that may work better.
no problem :]
If you want to try a different High Mileage oil my two suggestions would be M1 High Mileage and Pennzoil High Mileage
There's quite a few good threads on this. I'd try Valvoline Maxlife or Pennzoil High Mileage. Tried Castrol High Mileage and it didn't do anything.
I'm not sure but I think it maybe an o ring inside the oil filter adapter mount, no easy task on
those Fords.
