Hello Gurus, I am looking for an oil recommendation for a 1986 Ferrari 328 GTS with 23K miles. I live in Northern CA., great climate. Thank you for the help.
Thank You, great info.I owned a 1978 308 GTS and later an 1987 328 GTS, both had similar recommendations in the manual to use AGIP 10w-50 and/or 10w-40 AGIP. Both were semi synthetic and of course, ancient formulations. In the late 1990s Ferrari recommended for most of their 80s and 90s era cars to use Shell synthetic 5w-40. That (I believe) is still their recommendation. If you go to Ferrarichat, you will find many opinions and observations, which may shape yours.
Back when I had mine in the late 1990s to 2005, I used mostly Mobil 1 15w-50 as that was popular with most owners. I think toward the end of ownership I was using Pennzoil or Shell 5w-40, more closely aligning with Ferrari current recommendations. The main reason I switched to the 5w-40 was at cold start, the 15w-50 showed really high oil pressures...enough so, that I waited a few minutes before starting off to let it warm and settle down. (btw, do follow your owners manual recommendations to not rev the engine over 4000 rpm until the oil has warmed to over 170F, cold oil cannot get to the top of the engine and properly lubricate when cold) Once warm, get it over 7000 rpm at least a few times on each drive and enjoy that glorious noise!
There are no known oil related issues with these older 3 liter engines, they are stout. I wouldn't worry about using a quality 5w-40. If you are new to Ferrari ownership, I highly recommend you find a good Ferrari specialist for advice, whether dealer or independent. They can be very helpful to improving your overall ownership experience.
Ferrarichat was indispensible for helping me with various issues, that I was able to fix myself on my 328. Like the common tachometer failure, where it reads low. I removed it and sent it to Palo Alto Speedometer for repair. My speedometer quit working and it was just the sender that failed. It is screwed into the transaxle. I ordered a new one and it was a simple swap. I learned to do my own transaxle fluid changes, and oil changes. It was a fun car to wrench on. I found a great "old school" Ferrari trained mechanic to work on it for valve adjustments and tune ups. He was truly a master with these cars and kept it running beautifully.
Be sure to read the entire owners manual from cover to cover. There is some really good information in there. Not only maintenance and service info, but basics on how to properly use the heater and AC controls and checking the oil level and coolant levels.Thank You, great info.
There are only two quality oil filters for this car, the factory approved UFI and the aftermarket Baldwin B253. The filter is mounted standing up, and has an internal standpipe and back flow valve. All other brands of filters that claim to cross reference either do not have a standpipe (Mobil 1 for example) or the back flow valve doesn't work properly (Fram). If either (or both) are not present, the oil pressure will take much longer to come up upon cold or warm start, as all the oil drains back to the sump when you shut off the engine.Have a customer with one and we use a UFI filter and Mobil 1 15w50
Here's my 1987 328 GTS from back in the day (over 20 years ago!)...I loved that car...it had some great upgrades over the previous 308 series. More interior room, better AC, more power, better brakes. But retained those good looks, balanced handling, and great engine noise. Just a classic looking Ferrari.Post some pictures of this from 1986. That was one of my favorite cars back in the day.
Exactly!Just a classic looking Ferrari.
Of course.Remember when this car was manufactured 5w40 wasn't readily available.
Just remembered another reason I went to using the Pennzoil 5w-40 euro oil. Not only was the oil pressure rather high while cold with the 15w-50, but it seemed rather high even when warm/hot. I ended up taking the car to my independent Ferrari specialist and he was able to adjust the oil pressure. I think he said he adjusted or shimmed a valve or some component in order to lower the operating pressure a bit, and also said to use 5w-40.Have a customer with one and we use a UFI filter and Mobil 1 15w50
Hardly "gutsy". High oil pressure were a known issue on some older Ferraris, that can get out of calibration. On most cars, which do not have an oil pressure gauge, how would you ever even know there is a high pressure issue? The idiot light only identifies low pressure.Gutsy move taking your Ferrari to an independent "specialist" to "adjust" the oil pressure.
Was money burning a hole in your pocket?
Also seems like everyone is in southern Florida or California and given the fact that proper xW was being used, I don't get the comments regarding oil not reaching here or there ... and it didn't sound like anyone was using a 10/15/20W in northern Alaska during winter months.No?
All my 308 GTS photos are before I owned a digital camera...and I got my first camera just before I sold the 328 GTS...so very limited.Any post about a 308 or 328 is useless without more pictures. Best looking car(s) in the history of forever. I'll fistfight whoever disagrees.
Funny you say that. Same customer had us install the updated oil pressure relief valve springJust remembered another reason I went to using the Pennzoil 5w-40 euro oil. Not only was the oil pressure rather high while cold with the 15w-50, but it seemed rather high even when warm/hot. I ended up taking the car to my independent Ferrari specialist and he was able to adjust the oil pressure. I think he said he adjusted or shimmed a valve or some component in order to lower the operating pressure a bit, and also said to use 5w-40.
