Looking for some oil recommendations. I've done (too much) research, and I think I've narrowed it down, but I could use a second opinion.
Answers to questions listed here:
- Car: BMW 740i (E38)
- Manual Recommended: 5W-30 or 5W-40; research indicates ACEA A3/B3, API SJ/CD, EC (LL-98).
- Driving style: Aggressive, non-track.
- Daily drives: Lots of short local trips, many short freeway trips, occasional long trips.
- Known problems: none, other than it has an M62 (heh).
- OCI: 7,500 miles max; wouldn't mind reducing that if appropriate.
- Other: Engine runs hot by design.
- Would like to have the BMW certs on there, but I'm not overly attached to those if the reasoning for using something else is strong.
- Won't use BP or Mobil, so that rules out two really easy choices for the E38 (Mobil 1 0W-40 and the BMW-branded Castrol).
- I'd consider Lubro Moly Longtime High Tech 5W-30 or Total Quartz Energy 9000 5W-40, but it's hard to sort out the US versus Euro specs.
- Valvoline Synpower MST 5W-40, which is by far the least expensive, but some say not to use an LL-04 outside of Europe.
- Motul 8100 X-cess 5W-40, which is quite surprisingly, less expensive than the PU.
- Pennzoil Ultra Euro 5W-40, which I gather is a replacement for PP European Formula Ultra, and is more expensive than the Motul.
